Yuri Khodos wrote:You can get slip as an analogue voltage input (option 3 or 4 in TC Slip Source). SDL3 can calculate the slip automatically in Speed and Distance Setup. So what you can do is: receive wheel speeds into the SDL3, configure “Wheel Slip (Percent)” channel and use this channel to configure an Aux output. So at the end you should receive Aux output from the dash into the ECU.
I would really like to do this since my digital inputs are already tied up but Yuri's statment above doesn't quite make sense to me so if anyone with experience can confirm if it is possible. I have an ADL & a M48 pro.
This feature is not well documented in the M48 software but it seems to suggest that it expects to receive an analog voltage into either the Aux temp or Aux volt input that is proportional to wheel slip. Yuri's statment suggests we can generate this using an AUX out of the SDL3 for instance, However as far as I know an SDL3 (or the ADL that I have), cannot generate an analog voltage output - only PWM or Frequency?
So my question is, can this really be done? - if so please elaborate a little.
I will try PM'ing Yuri also and post a reply if I get any further info.
Motorsport Electronics Ltd.
