GM 3bar map sensor
GM 3bar map sensor
Postby Sal on Sun Aug 26, 2012 2:45 am
how should I setup this>? when i set it up as a delco 300kpa I get only 65kpa at test.... if I set it up as a high accuracy 300 kpa (setting 310) I get 117 kpa?
helllppp
Sal
Re: GM 3bar map sensor
Postby OmarK on Mon Sep 10, 2012 10:46 am
We may have calibrated the GM MAP sensor before, can you tell me the part number and I'll check if we have the correct calibration for you.
OmarK
